Page 4 of 23
FirstFirst ... 2 3 4 5 6 14 ... LastLast
Results 91 to 120 of 677
  1. Banned
    Jun 2024
    [Attachment 83237 - Click to enlarge]
    Originally Posted by stacyy View Post
    I figured out why Zen Player is used; basically, HD-quality videos hosted on VdoCipher require ZenPlayer to stream on rooted or WV L3-supporting devices. You can easily play SD videos hosted on VdoCipher without ZenPlayer, and you can also get keys for them using this extension.
    and bypassing WV L1 is a less discussed topic on public forums.
    https://zerospoker.com/video/reglas-de-una-partida-de-poker/
    1080p
    --key 2be8c71741825b9c852ec9a96552cd71:1217954a5f98c407fa71cac4f65e02fd
    --key c7ef633dabce502f92c5ec7f6d9b8964:6531758ffaf3e697177f012f4a5f0790
    --key a9d4b10aa2f851a8880881193041bccd:fde6c730a2957091f3b0d797335978cb
    --key 9a9e3c8327e3537e887a31d016cd92c5:47ba86e2b4727367bab2b4201f4ee575
  2. Nice work!!! Works perfectly, I love it.
    I have only one little problem, I use it on chrome and firefox with a real L3 cdm but on live content from pr!m3_V!d30, if I play it with the extension activated, redirect to the mpd SD version, but if I play it without the extension, then play the 1080p mpd
    Why does this happen? Any solution?
    Thanks.
  3. Works great! thanks for the improvements to it!
    Does the V3 give you the possibility all the collected data-s for different url-s
    save to an a json list?
  4. Originally Posted by parotris View Post
    Thanks.
    1080p on FREEVEE requires a ChromeCDM , but you're using an L3 Android CDM. I'm actually surprised that they automatically downgrade the keys and stuff and don't just return "VMP validation required", which they normally would with WidevineFetch if it wasn't for the custom module.
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  5. Originally Posted by sk8ordi3 View Post
    V3? We're on v0.8. The extension has been saving the collected keys in chrome.storage.local since v0.1, see here: https://discord.com/channels/1016904519847780353/1298951880373833809/1299729643284336701
  6. Originally Posted by larley View Post
    i mean V3 = Manifest V3
  7. Yes, accessing the webRequest Api, is still possible, but you can't, block, redirect, etc. Requests anymore, just view them. That was a confusion on my end
  8. Originally Posted by larley View Post
    Thanks.
    I understand, thank you very much for the explanation.
  9. Originally Posted by larley View Post
    Brilliant. worked like a charm.
    Thanks.
    Apr 2024
    Lettonia
    Thanks.
    Same for me I got Sd and not 1080p
  11. Originally Posted by larley View Post
    One question can you in the future add the manifest copy like you did with key and cmd?
    https://i.imgur.com/L6JKNOH.png
    And really congratulations you made a spectacular plugin!
  12. Hi everyone, here is also to save the command to a cmd batch file. You will have to save in the directory where N_m3u8DL-RE is located and click on it and all this is done automatically after the file is automatically deleted.
    [Attachment 83263 - Click to enlarge]
  13. Originally Posted by kingkong0 View Post
    https://github.com/DevLARLEY/WidevineProxy2/releases/tag/v0.8.1
  14. Originally Posted by larley View Post
    thank you bro
  15. Image
    [Attachment 83277 - Click to enlarge]
    I am not getting HD streams on Amazon with chrome. edge is having problems with the extension and wont load the video. Pls help. I need to download in 1080p and 5.1 AC3
  16. Originally Posted by sesamap159 View Post
    Can you make a xpi file of your mod for firefox? Thank you
  17. Originally Posted by Alcross888 View Post
    for that you need L1 CDM
  18. I am getting a 403 forbidden error on hulu. Any solution?
  19. Amazing work, thanks a lot! Really simplifies everything regarding L3
  20. Thanks a ton! This is really helpful!
    Dec 2021
    england
    look like directtv block it, was work in other day but not now
  22. Member
    Sep 2005
    Darkest Peru
    Edit:
    Update Chrome. Now the only error I get after installing is:
    'background.scripts' requires manifest version of 2 or lower.
  23. Originally Posted by Alcross888 View Post
    [Attachment 83531 - Click to enlarge]
    Delete what I crossed out in the screenshot to download E-AC3 5.1ch. 1080p need L1
  24. Member MartinTH's Avatar
    Oct 2024
    Germany
    DevLarley is already working on a PlayReady Extension.
    On Amazon it will then also be able to access higher Video Resolutions (1080p) and higher Audio Tracks (DD+)
    I'm very curious to see when this new Extension will happens.
  25. Originally Posted by larley View Post
    The addon won't be able to solve this, but I found out that the 2113 error code also indicates a "connection issue", which was caused by my interception using HTTP Toolkit. I don't know why but it's impossible to intercept this app
    Following instructions I was able to get ext to work with browsers. But as noob Id like to ask if its possible to somehow use this to fetch keys on android ps apps via the emulator or phone, that dont use browser? I cant find anything anywhere that specifically adress this.
  26. Member
    Nov 2024
    europe
    i keep getting the 403 forbidden error is there anything to be done ?
  27. Originally Posted by webdl View Post
    403 on play or from extension ?
  28. any fix for VDOCIPHER ? player show error "2074 Open in android app"
    other sites working
    Thanks for your work
  29. @Larley
    sorry for my great ignorance, but on latest 0.82 version, where/how to see keys?
    [Attachment 83642 - Click to enlarge]
    it's from mediaset. really easy to do. also exported json, empty file.
    also i get error on my browser (slimjet)
    [Attachment 83643 - Click to enlarge]
  30. Member
    Dec 2021
    england
    Originally Posted by whs912km View Post
    @Larley
    [Attachment 83644 - Click to enlarge]
    white: turn it on
    red: keys will show list in there
